Fuel Hose Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2010, 04:22 PM   #1 (permalink)
View gbdusty's Photo Gallery
Fuel Hose Leak
I have a leaking rubber fuel hose under my hood. I was wondering if I remove the EFI relay in my fuse box is that enough for me to now remove the old fuel hose without spraying gasoline all over the place? I am not very good with cars as this is my first but I am trying to learn.
gbdusty is offline   Reply With Quote
Old 07-09-2010, 07:26 AM   #2 (permalink)
View hungt1999's Photo Gallery
Yes you can remove the EFI relay and attempt crank the engine a few time to relieve the fuel pressure. You can then disconnect the line without fuel spraying. However, due to gravity and siphoning effect, gas can still flow (not spraying but a small flow) depending where you disconnect the fuel line. If the disconnect point is located below the fuel tank elevation, then gas will flow out. That is what I observe last year when I replace my entire fuel line
hungt1999 is offline   Reply With Quote
Old 07-09-2010, 07:52 PM   #3 (permalink)
View Steelballz's Photo Gallery
I know from experience, fuel will always leak out a little no matter what you do...whatever you try just changes how much/little comes out lol.
I would change it soon anyway though.
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
Old 07-09-2010, 07:54 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
if you take the line loose at the fuel sender under the back seat it won't siphon.
Old 07-10-2010, 09:02 AM   #5 (permalink)
Thanks for all the info guys, after trial and error I finally got it done this morning. It was pretty difficult clamping the hose in such a tight space.
Old 07-10-2010, 10:09 AM   #6 (permalink)
Bitter's Avatar
just make sure you used the right kind of line for this repair. I used 'fuel line' when I had to repair steel line at the fuel filter...after a few years it began to seep and leak! you need EFI fuel line which has an inner liner and is impervious to pressurized fuel.
