Tachometer Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2010, 08:06 PM   #1 (permalink)
View musclecar64's Photo Gallery
Tachometer Install
I just bought a Sunpro mini tach for my 94 corolla, and I'm planning on installing it this weekend. The only problem is I don't see any grommets in the firewall I can run the wires through. Where can I run those wires? is there an ok place to drill, run and plug?
musclecar64 is offline   Reply With Quote
Old 07-08-2010, 08:43 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
There is a rubber bung in the firewall that you can use on your driver's side. It's located directly underneath the air filter piping that leads to the throttle body. It has ribbed edges on it. The wires will come out under the dash, right by your accelerator pedal. I used it to put my amp power cable through. Very handy. Just drill, poke or cut a small hole in the bung and you'll be good to go
Here's some photos:
EDIT: Here's another photo:
Old 07-08-2010, 09:05 PM   #3 (permalink)
Is there any possible way to re-route the wires from there to up behind the instrument panel?
Old 07-08-2010, 09:16 PM   #4 (permalink)
Full Throttle
Yeah it'd be easy to re-route the wiring so that it goes behind the instrument panel. The easiest way would be to remove the instrument cluster, tape a straight piece of metal (such as from a coat hanger) to the wires and poke it up through the dash until you see it coming through an opening. There are quite a few gaps so you're bound to find at least one to go through.
Old 07-09-2010, 07:39 PM   #5 (permalink)
View Steelballz's Photo Gallery
^^with doing that it helps if you take out the section of the dash that houses the radio, makes it so much easier IMO.
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
Old 07-09-2010, 10:48 PM   #6 (permalink)
View agmgranturismo2006's Photo Gallery
can you tell how to connect the tachometer wiring i know that there are 4 wires
1-ground
2-Tachometer light
3-Tachometer Electrical power
4-Tachometer signal
but how i connect those wires actually to the car?
[SIGPIC]GRAN TURISMO the real driving
simulator
agmgranturismo2006 is offline   Reply With Quote
Old 07-10-2010, 02:36 PM   #7 (permalink)
1-ground
2-Tachometer light
4-Tachometer signal
Finished the install. Ground went straight to negative battery terminal (got lazy after a few hours of working in the heat). Positive (red wire) went to positive terminal on battery. White (illumination feed for tach backlight) was spliced into green wire (instrument cluster illumination feed) from dimmer rheostat. Green (tach signal) is back-fed from plug on negative wire for the ignition coil. Works great. Mounted the tach on the top steering column cover at an angle so it slightly blocks the "cool" part of the temp gauge, but none of the speedometer.
Also: thanks to kiwi-corolla for the advice on running the wires!
Old 07-10-2010, 06:07 PM   #8 (permalink)
tank you for your help and great illustaration
simulator
Old 07-11-2010, 01:58 AM   #9 (permalink)
Lanuza_fox's Avatar
View Lanuza_fox's Photo Gallery
1-ground
2-Tachometer light
4-Tachometer signal
I installed a sunpro mini tach using the radio's wires to power the tach and the diagnosis plug under the hood to get the tach signal
ground- use the brown radio wire
tach light- green radio wire
tach power- blue with yellow stripe wired
tach signal- IG(-) slot in the diagnosis plug under the hood
for pics go on my cardomain http://www.cardomain.com/ride/3212190
Lanuza_fox is offline   Reply With Quote
Old 07-13-2010, 02:17 PM   #10 (permalink)
Gameroom cash: $128158
View jawsofire's Photo Gallery
I'm looking to install one of these. Anyone know if they make pillar pods for the Corolla? I want a tach, but don't know where to mount it. I want it to look good and not block anything.
jawsofire is offline   Reply With Quote
