Stereo won't turn on after installing tach - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2010, 03:19 PM   #1 (permalink)
View musclecar64's Photo Gallery
Just installed a tach on my 94 corolla. Gauge illumination works, gauge works, but now my stereo won't turn on. Too hot to troubleshoot it outside right now. Any ideas? Could it have to do with disconnecting and reconnecting the negative battery cable a few times?
musclecar64 is offline   Reply With Quote
Old 07-10-2010, 03:31 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Try checking the fuse inside the cabin for the stereo (yellow 20-amp).
Old 07-10-2010, 06:43 PM   #3 (permalink)
4afte FTW
pnyk33's Avatar
View pnyk33's Photo Gallery
this^
300 HP 4afte
pnyk33 is offline   Reply With Quote
Old 07-11-2010, 09:55 AM   #4 (permalink)
Negative. Fuse is good. Cigarette outlet still charges my ipod. And the face and volume dial do glow dimly, so illumination is still working.
Old 07-11-2010, 10:07 AM   #5 (permalink)
BigDAT's Avatar
View BigDAT's Photo Gallery
unplug the tach, and see if the radio works, if it does it means there isnt enough power (highly unlikely)
BigDAT is offline   Reply With Quote
Old 07-11-2010, 03:04 PM   #6 (permalink)
Full Throttle
Is it an aftermarket stereo? If so, check the fuse on the back of the stereo itself. It might be something completely different, but it's best to start with the simple things first.
Old 07-11-2010, 06:31 PM   #7 (permalink)
View Steelballz's Photo Gallery
is the ignition feed for the radio still ok, and if there is a fuse in-line on that is that ok along with the fuse on the back of aftermak=rket stereo's scott mentioned?
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
Old 07-12-2010, 12:25 AM   #8 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
I had an issue with the ignition hot wire taking a bit shit on me when I installed my after market radio.. I had to hot jump it at the cigarette lighter.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 07-12-2010, 09:39 AM   #9 (permalink)
I don't know, but last night, I stopped at taco bell on the way home from a friend's house, and the car wouldn't crank when I went to leave. I had to call the guy and have him come give me a jump start. This is weird.
Old 07-12-2010, 11:02 AM   #10 (permalink)
BigDAT's Avatar
Sounds like a battery issue :/
Old 07-12-2010, 11:11 AM   #11 (permalink)
I'm going by the tech school I went to before today. Gonna ask the teacher if he'll let someone load test my battery and alternator. Wouldn't make sense if it was the battery because It was just tested at 600+ CCA a few months ago. I'm hoping It's just a wiring screw-up on my part.
Old 07-12-2010, 03:37 PM   #12 (permalink)
Full Throttle
Judging by what you said in your last thread, you hooked the positive wire for the tacho straight to your battery, meaning that it's always giving it power and will drain your battery. You need to hook the power wire up to a switched source, such as your cigarette lighter, clock etc.
Old 07-13-2010, 10:02 AM   #13 (permalink)
Yeah, went to the tech school (after having to be jump-started again). They charged the battery, load tested it, and load tested the alternator. All was fine there. Wiring the tach directly to the battery was my screw-up. Was creating a parasitic load on the battery, draining it even with the car off. Disconnected the tach, and I'll re-wire it CORRECTLY (red wire to something that only gets hot with key on, and a proper ground away from the terminal). Battery got drained again last night, had to het jump-start again, so I bought a charger and it's been charging since last night. Hopefully all it needed was a full charge and the tach to be wired correctly.
Old 07-13-2010, 10:53 AM   #14 (permalink)
BigDAT's Avatar
you can wire it to hot wire on your light switch, or run it to the hot cluster wire.
