1993 corolla tranny swap with prizm tranny? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2010, 10:32 PM   #1 (permalink)
View Prizolla?'s Photo Gallery
I have a 1993 Toyota Corolla that I replaced the motor and tranny out of a 93 Prizm. Everything works great except for the tranny shifting now. I can manually shift it out and it shifts fine. If i put it in drive and take off, it tries to take off in 3rd gear. The Prizm tranny is an overdrive and my car was originally a 3 speed. What all am I getting into changing? I tried changing the ECM but no good there. They both say toyota on them? Where do I start, or have I already reached the end. Any help would be appreciated. Local shops just laugh at me when I tell them what is up. It is getting very aggrevating!
Prizolla? is offline   Reply With Quote
Old 07-13-2010, 12:59 PM   #2 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
You did replace a hydraulic tranny with an electronic one. I'm not sure if there is a trsnny computer that controls the shifting along with the ECM, but you could probably research this.
zythr is offline   Reply With Quote
Old 07-13-2010, 01:59 PM   #3 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
You've got a different engine and transmission than what your car originally came with (bumped your displacement up to 1.8L and got another gear). To get normal functionality you need to swap out the wiring in your Corolla for the wiring in the Prizm, the transmission you put in is controlled by the ECM whereas your previous transmission wasn't. You may have swapped the ECM, but until it can send signals to the tranny it won't shift normally.
Also... grab the shifter assembly out of the Prizm, you'll need to install that so you can get the overdrive off button.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 07-13-2010, 04:31 PM   #4 (permalink)
Will I have to change all of the dash wiring in order for everything to work? Will it be easier to just put the tranny out of the corolla back in it? I don't know where to begin or end! Thanks for the information though.
Old 07-13-2010, 06:38 PM   #5 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
You going to need to a. change the computer b. change the harness and c. wire in new connectors.
you need the A131L trans...
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 07-13-2010, 06:54 PM   #6 (permalink)
You'll also need to find where you can install the ECT computer and connect it to the ECM computer, since the ECT gets its signal to shift from the ECM. Sounds like a lot of work and wiring.
