am going to be puttung the rear brake disc setup from a gxi on to my corolla saloon...
1) Is it a straight swap?
2) a new problem has come up, when i bought the rear disc conversion (from a gxi (ae102)) for my 93 corolla saloon,
the guys had cut the handbrake cable. my problem is that they cost £35 EACH
does anyone know if the handbrake cable from any other car would fit straight on? (levin ae111, avensis, impreza perhaps??)
need answers for this asap plz...
3) the rear discs and pads cost £££, is it possible to use discs from a different car (cheaper)? if yes which one?
this is off an ad of ebay for the size....
Mountings 4
Disc Diameter 266.0mm
Disc Thickness 9.0mm
Overall height 36.5mm
Centre Diameter 55.0mm
Minimum Thickness 8.0mm
the parts..
Thank you !!
ishaq
