94 Corolla 1.8...Won't Start need ideas of what to check next - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2010, 01:16 AM   #1 (permalink)
View kayy72985's Photo Gallery
I have a 94 Toyota Corolla 1.8. Engine wont start. We've replaced the distributor cap, wires, igniter, ignition coil, Checked all fuses and relays and they are fine. But still no spark. Where do I go from here? Thanks to anyone that can help
kayy72985 is offline   Reply With Quote
Old 07-15-2010, 06:52 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Sounds like you have been just guessing at the problem.
Get out your multimeter and start looking for where your voltage isnt.
Sorry I dont have a wiring diagram to point you in the right direction.
-SP
Old 07-15-2010, 09:12 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
This may sound like an obvious question, but have you pulled one of the leads out and tried to spark it on the engine block? That will tell you if there is definately no spark. Otherwise it is most likely just not getting any fuel..
Does the car have an engine immobiliser? If so are you absolutely positive it is off? Mine used to shut off the igniton coil AND the fuel pump, but still let the starter crank, so that may be another option..
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-15-2010, 03:27 PM   #4 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Check to see if you can hear the fuel pump prime when you turn the key to ON... if you don't hear it buzzing... check fuses and relays, then replace pump.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
