4afe tear down pictures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2010, 12:50 AM   #1 (permalink)
gt limited's Avatar
View gt limited's Photo Gallery
Got a 4afe recently
i pulled and check the rod bearings bad and the crank damaged so i decide to tear it down to a screw lolz
Many parts where missing too
Bear head will be cleaned and ported and used in the future
Bear block will be cleaned,sprayed and use for a spare or build
It seems like a 1994 4afe engine 7rib block
Sorry everything is still a bit dirty i dont buy the gas oil or degreaser as yet
Damaged
16 valve buckets
number one and two pistons crack
crank shaft the rod spun it
number 4 rod gone
Block piston code 2232
Crank code 22222
gt limited is offline   Reply With Quote
Old 07-23-2010, 12:53 AM   #2 (permalink)
gt limited's Avatar
Old 07-23-2010, 01:24 AM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Looks like a good project. Looking forward to seeing your progress
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
gt limited (07-23-2010)
Old 07-23-2010, 02:35 AM   #4 (permalink)
gt limited's Avatar
This will be like my specs and reference block and parts when i need them
I saving very hard towards a corolla still......i love keep spares when i have the space in case
I soon put up more cleaner pictures
well a small history of this engine
4afe
jz injectors
4age 20v ecu and distributer Silvertop air flowmeter
4agze gearbox
16 rims
full teins
i was in a ae91 corolla with JZ injectors and a 4agze gearbox.....well i heard it had a great topend speed
then they switched to a 4age 20v 6 speed
due to the closer gears the overreving starts hhehe until it had a rod knock....
Old 07-23-2010, 11:40 AM   #5 (permalink)
gt limited's Avatar
More cleaning today
Old 07-23-2010, 12:13 PM   #6 (permalink)
gt limited's Avatar
valve spring and retainers removal tool hehehe
bicycle seat pole
a hammer
a magnetic screw driver
Old 07-23-2010, 06:44 PM   #7 (permalink)
gt limited's Avatar
oil pump
Old 07-27-2010, 02:55 PM   #8 (permalink)
gt limited's Avatar
the spun rod i actually use a fine grit sandpaper rub down the inside and the lines disappear with minimum effort i think its good lolz
just the 2 broken pistons needs to be pressed out
i wish i could get some ARP bolts now for the rods
toyota bolts caused the problem why the motor is stripped down
Old 07-27-2010, 07:05 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
$46 at summitracing.com fits 1.6 and 1.8 engines.
The Following User Says Thank You to speedy25 For This Useful Post:
gt limited (07-27-2010)
Old 08-05-2010, 12:39 PM   #10 (permalink)
gt limited's Avatar
Old 08-13-2010, 01:21 AM   #11 (permalink)
gt limited's Avatar
The net says it better i throw out the block because it might flex already thats why the bearings damage
Old 08-13-2010, 12:42 PM   #12 (permalink)
gt limited's Avatar
Old 08-13-2010, 09:03 PM   #13 (permalink)
gt limited's Avatar
soon start the rebuild as soon i get 2 pistons
Old 08-21-2010, 12:40 PM   #14 (permalink)
gt limited's Avatar
Old 08-26-2010, 12:28 PM   #15 (permalink)
gt limited's Avatar
can this be reused
