I bought this car this weekend for my daughter and it runs great, but has a check engine light.
The only stored code is 12. I cleared the codes (verified before restarting), and the code comes back (about 2 seconds after restarting). Here's what I've found about '12':
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G")
AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
The exhaust manifold is cracked - I've ordered a new one, but I can't see that causing the code.
The cap/rotor were recently replaced (previous owner), and he says he'd never seen the check engine light before (it wasn't on during the test drive). I don't see any loose connectors or questionable wiring from the distributor, but don't know what to test yet as I don't have a book for this car.
Where should I start? I've got a Chilton's manual on the way. I'm no mechanic, but I have never had a problem with a car that I couldn't fix... eventualy
