rubbing felt when breaks applied - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2010, 11:31 AM   #1 (permalink)
View todd w's Photo Gallery
I feel a rubbing/sound and feel it in the pedal itself even.
I think it's in a back tire.
A pad is going maybe?
or time to bleed the breaklines?
todd w is offline   Reply With Quote
Old 07-31-2010, 04:06 PM   #2 (permalink)
anyone? anyone? Bueller?
Old 07-31-2010, 04:30 PM   #3 (permalink)
Gameroom cash: $200810
View ganda1f's Photo Gallery
Does not sound like you have air trapped in the brake lines. That gives a spongy feel to the brake pedal.
If pads and/or shoes are badly worn, meaning there is metal-to-metal contact between pads/shoes and disc/drum, then I suppose that could be felt in the pedal. But that would most likely also cause a terrible sound.
Otherwise, a pulsating brake pedal could be a sign of a warped disc, although, that would also be felt as vibration in steering wheel.
ganda1f is offline   Reply With Quote
Old 07-31-2010, 07:59 PM   #4 (permalink)
You asked for it...
View azcorolla's Photo Gallery
Cheap pads can do that, too. Pull the drum and if the pad isn't worn out, you might consider buying some good ceramic ones. Worked for me.
azcorolla is offline   Reply With Quote
Old 08-01-2010, 07:07 AM   #5 (permalink)
Thanks,
Over the last few months, after a rainfall if the car was sitting outside, I could hear a rubbing in the tire area in back.
Rubbing sound would diminish after driving it awhile, combined with lack of rain.
Car has sat outside last week and a half while I was working on starter, plus we have had record amounts of rain here for us.
this may be why the rubbing was so bad I could feel it in the brakes for the first time.
Moisture getting in there might be something contributing to issue.
Old 08-01-2010, 09:41 AM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
rust inside the drums. pull the drums and check for pitting/heavy rust and make sure that the shoes and drum surface are both smooth.
Bitter is online now   Reply With Quote
