Originally Posted by Yodadex
I would start with checking the ignition, fuel, and air system: check the wires, distributor, plugs, fuel lines, injectors, blah blah. There is a diag output in the engine bay, but you need the tool to read the codes.
No tools necessary, just a paper-clip or piece of wire
Originally Posted by 91shelby
Alright well i have my friends 1993 Corolla 1.8L and in order for it to start i have to sit with it turning over for about 15 secs before it actually catches and when its running the exhaust smells like its running lean.... Im thinking O2 sensor, is there anyway to pull codes? once it starts though it seems fine. at some point in the past the o2 had some water get on it,before the head gasket was redone, could this cause it?
Since your friend's car is a 1993 with OBD-I, look in the engine bay and you'll see a small black box next to the driver's side strut tower that says 'Diagnosis' on it. Get a paper-clip or a small piece of wire and put one end into the port labelled TE1 and the other end into the port labelled E1 (the labels are found on the underside of the diagnosis box cover, much like a fuse-box).
Turn the key to the 'ON' position, but
don't start the engine. If your connections are correct then the check engine light should start flashing. Keep note of how many times it flashes as this is the code it is giving you. For example, if the code was 35 it would flash 3-times, have a short pause, then flash 5 more times, then have a long pause. If it repeats the same code after the long pause then that means it's the only fault detected, but if it flashes for a different period of time then that means there is more than one fault. If it flashes continuously with no pauses in between then that means there is no fault detected at all.
If you do happen to get a code, then you can go to this website to find out what it means:
http://www.troublecodes.net/Toyota/
