'93 Corolla single 'click' while trying to start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2010, 11:06 AM   #1 (permalink)
View Novice_cardude's Photo Gallery
Well, it's sort of a long story, but I had a '93 Corolla behind my house that I'm trying to fix. A friend got a new car, and left hers at her apartment complex with expired registration so it got impounded. I went with her to get it out of impound, and it wouldn't start. there was a single 'click' any time you hit the key. We tried jump starting it, thinking it had enough battery power to engage the solenoid, but not spin the motor. no go. Wound up using her Impala to get it rolling, then dumping the clutch. Started fine that way.
I got it home, took the starter out of it, and brought it to Autozone. They said it was pulling high amperage, so I thought "Well, there's the problem" and bought a reman starter.
Popped it in, hit the key, and the same thing happened. I can hear the 'click' and now a sort of buzzing or humming noise like the motor is trying to turn as long as I hold the key on. The new motor is a bit shorter than the old one, but the mounting points and connections were identical, so i didn't think that would be an issue.
Where should I look now? Maybe there's an electrical connection issue to the starter? The battery may still be weak? Anyone else here had this problem and figured it out? I need to get this beast running because my sister may want to use it until she can get a newer car.
Thanks!
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 08-07-2010, 12:39 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
bad battery connection? poor ground? bad cables? loose terminals? weak battery?
Bitter is online now   Reply With Quote
Old 08-07-2010, 05:13 PM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
A. Bad Battery. B. Corroded Terminal not making a good connection. C. Bad Connection to starter.
Start with C.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 08-07-2010, 10:06 PM   #4 (permalink)
You asked for it...
View azcorolla's Photo Gallery
and, if the things above don't work, and since it came from Autozone, it could be another bad starter...
azcorolla is offline   Reply With Quote
Old 08-08-2010, 11:17 AM   #5 (permalink)
Okay, cool. Now I have something to check. I'll go out and make sure all the electronics are good. If all the connections check out i'll try boosting the battery again. If that doesn't work it's time to take the starter back.
Wish me luck!
'96 4cyl 5spd Camry
Old 08-08-2010, 11:38 AM   #6 (permalink)
View MrGiggles's Photo Gallery
Make sure to check the battery ground to engine block wire specifically.
1994 Corolla
Base/1.6 5spd
MrGiggles is offline   Reply With Quote
Old 08-08-2010, 01:46 PM   #7 (permalink)
Well i went out there and took off both battery terminal ends, disassembled all the connection points and thoroughly wire brush/cleaned them. Checked the grounds for luck, turned the key and she started right up! The beast rides again!
Thank you all for your help
'96 4cyl 5spd Camry
Old 08-08-2010, 04:30 PM   #8 (permalink)
Bad connections will do that. haha.
Corolla Number TWO
