Hi,
Is it possible for this to happen?
Here's some background info.. The car does not lose oil but, I am always forced to add more oil at fillup. As far as I can tell, it does not smoke... but the oil is disapearing. Last fillup, I added half a litre of the stuff.
Just today, checking into a problem that I've wrote about below, I opened the transmission fluid filler and a brown, almost oil black fluid came gushing out. It smelled briefly like transmission fluid. I put the plug back in before letting it all come out.
Could the engine oil be making it's way into the transmission? Since fixing an exhaust leak, I've been able to hear a disturbing noise that I've not been able to find it's origins. It kinda cranks. At times, it sorta sounds like it could be a bearing but not too sure.
It's mainly while driving straight and accelerating; from the drivers side it sounds like it's coming from the passenger front side.. but I'm not 100% sure. None of my friends drive stick so I can't compare while being on the passenger side but they're not too sure where it's coming from up front either... possibly driver side but.. not sure; (it's clearly not the driver side though!
). I've lifted the car and it looks alright and the wheel does not move in and out to indicate the bearing. So, I'm left with either the overfilled transmission fluid; would that make a weird noise if overfilled? The bearings, or something else.
Any ideas? On either subject?
