Low fuel light still on with full tank of gas - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2010, 05:03 PM   #1 (permalink)
Matt94MR2's Avatar
Gameroom cash: $247750
View Matt94MR2's Photo Gallery
I noticed my low fuel light turned on a little earlier then normal yesterday. I filled up at the gas station and it took less then 9 gallons to fill the tank. The low fuel light is still illuminated even after I have driven it for a day with an indicated full tank of gas. A few things that may be related:
1) I recently swapped over to a gauge cluster w/ tach but it has been working fine for a couple weeks now.
2) I swapped out the stock bulbs for some LED lights from superbrightleds about two days ago.
Everything seemed to be working fine until yesterday. I am leaning toward the LED lights having something to do with it but wanted to get some feedback before I pull out the gauge cluster yet again.
1994 Toyota MR2 Turbo, Gen3 3S-GTE, 278 rwhp, 12.8 @ 106 mph in the 1/4 mile
1996 Toyota Corolla, 4A-FE, 5-speed
Matt94MR2 is online now   Reply With Quote
Old 08-23-2010, 05:54 PM   #2 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
If I recall correctly, the fuel pressure/level send is different for the tachometer model than it is the non tach, but I thought it caused the level to be off, not the light to be stuck on. What I would try first is to unhook the battery and give it five minutes for the ECU to reset just to see if it does anything (kinda doubt it but worth a shot). I have LEDs in my cluster but they haven't caused issues. They are only the 194s though, not the smaller ones like the fuel light.
cipher93 is online now   Reply With Quote
Old 08-24-2010, 12:12 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
there is a separate sensor in the tank for the low fuel light, if you changed the bulb for the low fuel light to LED i would change it back thats probably your problem
Ive done a no-tach to tach cluster conversion without any problems or difference in fuel reading.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-24-2010, 04:13 PM   #4 (permalink)
Matt94MR2's Avatar
Thanks for the replies. It looks like the low fuel light indicator also uses a 194 bulb on the tach cluster so I had swapped it to LED. I put the original bulb back in and everything seems to work again. It probably turned on right after I did the install but it was the middle of the day so with the glare of the sun I guess I did not notice it until the following day.
Old 08-25-2010, 07:42 PM   #5 (permalink)
View Steelballz's Photo Gallery
I have the same problem with the low fuel light in my own.
never changed bulbs, but did replace the non-tacho guages for the tacho-version...one day the guage went down to nearly past the empty line at the bottom, and the light is on since...
any idea's?
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
Old 08-25-2010, 11:08 PM   #6 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
I put in a gauge cluster with a tach in my old Corolla, and then swapped out the bulbs in the tach one with LED's. The fuel light was always on. Pop in a normal bulb for the fuel light, and it worked normally.
There's always enough power flowing through to fully illuminate an LED if it's installed.
I also had to manually adjust the gauge needle several times to get the range right.
Since you haven't installed an LED, I would suspect that the low fuel sensor in the tank is at fault. If you still have the old cluster, try plugging it in and see if the light is always on. If so its the low fuel sensor.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 08-26-2010, 05:37 PM   #7 (permalink)
must be the sensor so, worked fine the last year or so...
