i waited hours for a reply to this thread for any help but no luck so far so i went ahead and adjust the K to dead top center. gave it a start and the only thing that happen was everything kept spinning the speed of the starter. like if the sparkplug were all pulled out. i didnt want to go the long way and put a jack under the motor and all that hell of works so i pulled sparkplug number 1 out and slide an extension down the cylinder and spin the camshaft till cylinder 1 was TDC. i had no idea if it was going to be on the fuel/air stroke or the power stroke but figure that's not as important except that the crankshaft position sensor might sent off the wrong reading so i went on by luck. here's what i did.
position the 1st cylinder to TDC using the extension down the cylinder by removing the sparkplug.
carefully slide the belt OFF the camshaft and wrap it tight on the HIGH line for the a.c
14mm socket to spin the camshaft into position ready for the air/fuel stroke.
slide the timing belt back on the camshaft carefully into a tight fit and install everything back in order.
went into the car and gave it a crank. car starts!! it sound almost like the RPM is reving a bit high but runs very smooth.
as of now i need to do a lil tweakin to get the RPM down right or maybe bring it back one tooth or adjust the throttle body after this rain could stop interruptin me for the 9th time TODAY.
