Belt Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2010, 04:04 PM   #1 (permalink)
View JetPax's Photo Gallery
Belt Change
So I want to replace the main timing belt on my 95 what kind of tools are needed? Also can anybody give steps and tips. Thanks
JetPax is offline   Reply With Quote
Old 08-31-2010, 07:52 PM   #2 (permalink)
View 94PrizmDD's Photo Gallery
Unless you have some knowledge on working on cars, id try seeking a mechanic or a friend, this is a major job.
94PrizmDD is offline   Reply With Quote
Old 08-31-2010, 08:26 PM   #3 (permalink)
Well I have worked on cars before not professionally or anything but when I owned a 65 ford falcon I had to do all my own mechanical work. Never done a timing belt but hey. I probably will have it done.
Old 08-31-2010, 09:35 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Here's a DIY on how to change the timing belt. Scroll about three quarters of the way down the page for the 4A-FE/7A-FE instructions:
http://www.856media.com/corolladocs/...beltchange.htm
Old 12-12-2010, 04:34 PM   #5 (permalink)
View Ford Falcon's Photo Gallery
Thumbs up
Nice link. I just took a look at this today while changing the timing belt on my '94 Geo Prizm.
I actually needed to get the water pump replaced because of worn bearings and decided to get the belt changed at the same time.
I bought a kit on eBay for the belt, water pump, and all gaskets, including the spark plug seals on the under-side of the valve cover.
I got a handy tip, for anyone who has had trouble replacing these spark plug seals. I knocked the original ones out with a narrow blunt tool, but getting the new ones back in was a pain. I didn't have a tool to press it into place. In the end I lightly coated the outer surface of the seal with some engine oil, and I also happened to have a 36mm 1/2 drive socket which fit the edges of the seals perfectly. I lifted up the metal tabs and then by hand I was able to press the seal back into place.
Ford Falcon is offline   Reply With Quote
Old 12-13-2010, 05:09 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Be REAL careful with ebay parts. They are cheap for a reason.... most of them are crap as well.
Hopefully you got something of OK quality.
-SP
