Battery Light is on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2010, 08:35 PM   #1 (permalink)
View itreflop117's Photo Gallery
Yea, haven't been on here awhile. The problem is exactly how the title states. When I turn my car on all the way the battery light stays on. However, whenever I accelerate it turns off and stays off. Then when I slow down to a lower rpm it turns back on.
I figured I should buy a new battery just to make sure. ( I needed a new one anyway.) I bought a Duralast Gold. So I went out driving again and the same thing happens. I accelerate the light turns off. When I get to a lower rpm and at idle it stays on.
My question to you guys is this: what causes this light to stay on? My dad thinks it's an alternator problem where it's not charging the battery enough at idle/low rpms OR there is a short somewhere in the car...
ANY info/tips would be awesome. Thanks guys for your time. I really appreciate it.
itreflop117 is offline   Reply With Quote
Old 09-01-2010, 09:02 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Could possibly be a problem with the alternator, but the first thing I'd check is the alternator belt. Make sure that it's tensioned correctly and isn't worn. Then check that the wiring harness for the alternator is secured tightly, and not burnt or cut in any way. If everything checks out ok then it's time to test it with a multimeter.
With the engine off, connect the multimeter to the battery terminals and make sure you have at least 12 volts. Now start the engine and check the battery voltage again. It should be between 13.5 to 15.1 volts. Now turn on the headlights. The voltage should drop and then come back up if the charging system is working properly.
I'd recommend taking the car to an auto electrician and getting the problem professionally diagnosed. Most places do the diagnosis for free. They have all the right equipment to do proper tests (such as an amperage output test) on the charging system. Good luck!
Old 09-01-2010, 09:46 PM   #3 (permalink)
ahh i'm glad i came here for help. you always have the right thing to do man. i appreciate it thanks!!! i'll update tomorrow if anything.. my dad is gonna replace the alternator for me. =DDD
Old 09-02-2010, 06:41 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Most probable reason is the regulator/rectifier is going bad. Most people dont know how to replace or how to find the part so they install a new alternator.
Using a voltmeter confirm that you dont have 13.2 to 14v when the engine is above idle.
-SP
Old 09-02-2010, 07:06 PM   #5 (permalink)
View 96coroll's Photo Gallery
I would recommend what the guys have said here. I've down it before it's not very difficult to test the battery at idle. My first impression would be the alternator.
This sort of problem has happened to my bosses ford E - 150, the exact same symptoms.
Good luck, shouldn't be much of a problem to fix.
96coroll is offline   Reply With Quote
Old 09-02-2010, 09:23 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
It is the alternator, there are plenty of threads around pointing at the alternator when the battery and and sometimes the brake light come on at the same time.
REN69 is online now   Reply With Quote
Old 09-03-2010, 05:07 AM   #7 (permalink)
View 94PrizmDD's Photo Gallery
You can also take it to Advance or Autozone. They charge and test your battery for free. Then you can rule out the battery if its good.
94PrizmDD is offline   Reply With Quote
Old 09-03-2010, 12:53 PM   #8 (permalink)
View Dannyboy1277's Photo Gallery
I had a similar problem but all they had to do is adjust the alternator belt.
Dannyboy1277 is offline   Reply With Quote
Old 09-03-2010, 04:00 PM   #9 (permalink)
View Steelballz's Photo Gallery
had the problem on my car before, somehow the nut holding the thick wire on the alternator came a bit loose...tightened it and it was fine again.
if this doesnt work, put in a new alternator
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
Tags
battery, battery light, corolla
