96 corolla cuts off at sometimes when accelerating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2010, 08:55 PM   #1 (permalink)
View bory267's Photo Gallery
on mi 96 corolla when im going 55 miles per hour its shuts for at least one second.or cuts off for 1 or 2 second can anybody help me on this one i already replace crank shaft sensor spark plugs cables egr valve. egr vacuum modulator.throte .fuel injectors please help
bory267 is offline   Reply With Quote
Old 09-28-2010, 09:38 PM   #2 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Replace the fuel pump relay. Also check the power lines going to the fuel pump to make sure they're not damaged.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 09-28-2010, 10:50 PM   #3 (permalink)
should the car start with bad relay gas filter replaced too why you think the relay?
Old 09-28-2010, 10:54 PM   #4 (permalink)
BoyYota's Avatar
I had a bad relay and it would just make the car shut off at random times, sometimes it would be fine for days or weeks then it would shut off while driving and not start back up or just not start at all until it felt like it. Went through spark plugs and wires, fuel filter, treatments and several valves such as the FPR before I realized it was the relay.
I understand your problem doesn't sound quite like a relay, but it could be, and it's a cheaper fix to try than a fuel pressure regulator, etc.
Old 09-29-2010, 12:17 PM   #5 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Sure. Sounds like it's time to sell. How long are you going to keep this car?
zythr is offline   Reply With Quote
