Key Isn't Turning HELP!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2010, 04:53 PM   #1 (permalink)
yer
View yer's Photo Gallery
gen 7 Key Isn't Turning HELP!!!!
So my 95 corolla was running perfect till my clutch slave broke and now my keys fit but wont turn over to start my car i need help i haven't drove it for about 1 week and an half so does anyone Know help me ASAP!!
yer is offline   Reply With Quote
Old 10-06-2010, 07:50 PM   #2 (permalink)
monkeypower102's Avatar
View monkeypower102's Photo Gallery
Had this same problem with mine once too. The key fit but wouldn't turn in the ignition, although it unlocked the doors. Everything locked up on me and it was lame. Turns out that my key was worn down in a way where the metal didn't fit right on it. Ended up making another key.
Might be the same problem you're having.
"The Frequent Flyer!"
monkeypower102 is offline   Reply With Quote
Old 10-06-2010, 11:55 PM   #3 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Only time this happened to me is when the steering column on my dad's old F150 went bad.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 10-08-2010, 12:04 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Dont overlook the obvious- Lack of lube in a lock will make it stick so it wont owrk. I've only had one lock wear out where I had to refit the tumblers. All the rest that quit were from lack of lubricant.
Japanese car locks, especially doors are notorious for getting water in them and freezing. Combat it now with some lube.
-SP
Old 10-08-2010, 01:22 PM   #5 (permalink)
View m_wnzl's Photo Gallery
or even the more obvious, try moving the steering wheel, sometimes it can cause the ignition switch to stick
m_wnzl is offline   Reply With Quote
