Update: I went to a salvage yard and they had 2 Prizms and still had the O2 wiring and I took off the tape that was on them like that was on mine because it didn't look like a factory would do it, with electrical tape, and the wiring looked just like the pic I posted, so it wasn't messed with, it's the same with all Prizms thanks goodness, so i tested the O2 sensor like the video on youtube with a propane torch and a digital meter and it was bad, so I put a new one on and waalaa no check engine light. How weird is that, take car for a test drive all over town, pay for it and on my first drive the check engine light comes on for a bad O2, never had that happen before ;}LOL
I just got a 97 Prizm LSI & within a few miles of just paying for it & heading home the check engine light came on and took it to auto zone and a codes came up for Heated oxygen sensor - bank 1 sensor 1 (HO2S11) & also Slow response (Heated oxygen sensor bank 1 sensor 1)
I noticed that the wiring to the front 1st oxygen sensor is had electrical tape on it, so I took it off to get a look at what was going on and it was frayed, there is a big gray wire coming from the factory wire loom then stops and a smaller black one going in it from the opposite direction coming from the connector and or coming out of the gray wire and the gray wire is frayed and pulled back onto itself just like shielding on a coaxial cable for cable TV, when you install an end before cripping.
I've never seen anything like that on a vehicle and I've been a novice do it your selfer since my first vehicle and this is a first I've see wiring like this. Check out the photobucket pic...
As you see in pic there is a light brown wire coming from factry wire loom same as gray one to the connector mounted on the electric fan, but the bigger gray wire stops and then the smaller black wire goes on to the connector, after that the blue and white small O2 sensor wires goes from the connector. Anybody else looks like this or has any idea what's going on? Why is the gray wire so much bigger than the light brown one? How is this to be fixed? Any help much appriciated, Thanks...
http://s1190.photobucket.com/albums/...0-14-20105.jpg
18 y.o. daughters car: 1997 Geo Prizm LSI<Toyota Corolla drivetrain, Emerald Mica Metallic (Green) Tan Interior, AC, AT, JVC KD-S36 CD/USB.
1993 4WD DLX 187K non original rebuilt in 03 engine, previous owner a douche', I hope to give in a better life!
