I got this engine squealing.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2010, 07:36 AM   #1 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
I got this engine squealing everytime I start the engine cold but as the car gets warmer, it stops. To me, I'm thinking its a water pump bearing but not sure as I just got that replace in March or so along with a new t-belt. It's a '95 Geo Prizm with a 1.8L and its my DD/Winter car.
This is a video I found on youtube and it shows the same engine squealing as the one I have at cold start up:
Let me know what you guys think. Thanks.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 10-25-2010, 11:06 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I thought the same thing on my car. It is really a rusty power steering pulley.
-SP
Old 10-26-2010, 07:17 AM   #3 (permalink)
DOHC VTEC
-SP
So your's a rusty pwr str pulley that caused that squealing?
I used a stethoscope to pin point the problem at the pwr str pump, water pump, and othe various place around that accessory belt area but didn't hear much. Then I had a classmate listened to the noise with a stethoscope and he said its not the water pump. He said its a loose Alt Belt. Because when he turned the alt belt 90 degree, he's able to to turn it almost 180 which means its a bit loose. So I'll see if it goes away after tightening that up.
204whp/157wtq
Old 10-26-2010, 08:13 AM   #4 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Well, has it had the belts serviced? Clearly it's a belt problem, whether it's the fault of a bad or rusty pulley you'll have to see when you get in there and give everything a good look. Remove the belts and inspect all pulleys, give them a nice cleaning with a wirebrush or some high grit sandpaper, and replace any belts that don't look OK.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 10-26-2010, 12:21 PM   #5 (permalink)
View Suprawillis's Photo Gallery
Go to autozone, buy a can of belt dressing. Spray on your power steering belt. If the squealing goes away, time for a new belt.
1995 rolla dx 5spd. A bajillion miles on the original engine and tranny.
http://www.youtube.com/watch?v=so1NxyFFENw
http://www.youtube.com/watch?v=SpHDnAhj2d8
Suprawillis is offline   Reply With Quote
Old 10-27-2010, 04:38 PM   #6 (permalink)
DOHC VTEC
I checked all accessory by using brake cleaner and dialectric grease on the belts and there's no change, so it was the water pump bearing after I rechecked it with a stethoscope. Its a defect part and I just replaced it in March or April of this year.
204whp/157wtq
Old 10-28-2010, 03:24 PM   #7 (permalink)
DOHC VTEC
It was the water pump. I replaced it in class and now its all good. The old pump bearing felt rough and I can't believe I have it not even a year and its already bad. Freaking aftermarket pumps.
204whp/157wtq
Old 10-28-2010, 07:08 PM   #8 (permalink)
View good_old_geo's Photo Gallery
i had the same problem before. check the timing belt tensioner pulley. I had my timing belt snap because the pulley was no longer rolling. But its okay since the engine is non-interference
good_old_geo is offline   Reply With Quote
Old 10-28-2010, 08:44 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
I thought it was the water pump but when I checked all components it was a rusty PS pulley causing the squeak.
-SP
