Window Manual to Power Conversion Help! Any help is good help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2010, 11:51 PM   #1 (permalink)
View hobbzilla's Photo Gallery
I recently had a run in with a deer in my 1996 Corolla. It took out both my front and passenger side doors which were power windows and locks. I went to a junk yard and luckily found doors that were the same color. It was a 1993 and had manual windows and locks. All my interior is still good on my old doors. So...
1.) Will I be able to convert my new doors with the power parts I already have? Such as bolt places for my motor.
2.) Does anyone have any advice or place were I can find a guide to doing so. I have a Haynes manual and I'm sure it will be able to guide me through as long as there are spots for me to mount the power equipment.
Thank you in advance for your help or at least taking time to read!
hobbzilla is offline   Reply With Quote
Old 10-31-2010, 11:57 PM   #2 (permalink)
View ae92gtz's Photo Gallery
piece of piss, all the bolt holes should be there and you just swap everything over, if you cant do it by looking at it I doubt a manual will be any help
ae92gtz is offline   Reply With Quote
The Following User Says Thank You to ae92gtz For This Useful Post:
hobbzilla (10-31-2010)
Old 11-01-2010, 01:05 AM   #3 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
Apart from swapping over everything from the doors (cards, arm-rests, motors etc), the main thing I'd be investigating would be if you needed the BCM from the donor vehicle as well, as I'm fairly sure the wiring is routed through there to give logic control over when you can and can't raise/lower the windows, otherwise you'd have to wire them up with ignition-switched 12V (some cars allow you to put the windows up even after you've turned off ignition, but you can't put them down etc)
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 11-01-2010, 01:52 AM   #4 (permalink)
he's already got power windows etc so the wiring is all there its the new doors that have the manual winders
Old 11-01-2010, 07:24 PM   #5 (permalink)
Token Aussie
so he does, have had a bad run lately mis-reading posts, maybe it's a sign I shouldn't be on the forums at work :P
Old 11-01-2010, 07:30 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $614831
View Zembonez's Photo Gallery
Other than swapping parts, you should have no problem at all. The door shells are the same part. It'll work just fine! Happy swapping.
Zembonez is offline   Reply With Quote
