half shafts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2010, 01:53 AM   #1 (permalink)
Gameroom cash: $151000
View demonics12's Photo Gallery
half shafts?
how do you know when they go bad? i have 220k on what appears to be stock shafts.
im also wondering if stock shafts will hold up on a lowered car. do i need to upgrade?
demonics12 is offline   Reply With Quote
Old 11-01-2010, 01:56 AM   #2 (permalink)
View ae92gtz's Photo Gallery
what is a half shaft?? a CV joint?? or the actual shaft??
wow ok... just googled it... do you americano's seriously replace the whole shaft with both joints rather than just replacing the outer joints if they flog out??
Last edited by ae92gtz; 11-01-2010 at 02:00 AM. Reason: added WTF factor (whats the coolest reason for editing?)
ae92gtz is offline   Reply With Quote
Old 11-01-2010, 01:59 AM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
Half shaft last nearly forever as long as the boots on the CV joints are not torn and there are no clicking sound on turns. The shaft should do fine on a lowed Corolla unless you're throwing out over 500 HP, the shaft will hold together.
At 220K the rubber boots might be ready to tear. It's easier to replace the entire shaft than to mess around with a replacment boot.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is online now   Reply With Quote
Old 11-01-2010, 02:14 AM   #4 (permalink)
im noticing a vibration at certain speeds, ive done quite a bit of work and i feel that they might be going.
Old 11-01-2010, 02:56 AM   #5 (permalink)
have you taken all the logical steps like getting wheels balanced?? (sorry, unsure on your knowledge levels)
Old 11-01-2010, 03:03 AM   #6 (permalink)
the wheels and tires are about 8 months old, im pretty sure the wheels and tires are in good shape.
ive just never had these go bad before.
Old 11-01-2010, 03:08 AM   #7 (permalink)
8 months old is old enough to have worn or for you to have hit something, start with a balance as its the cheapest, if it goes away then you dont have to spend anymore money
Old 11-01-2010, 10:17 AM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
It is common to have a bad shaft without leaking or clicking. Usually you can find the wear by moving the axle by the outer joint. Any movement means its toast.
-SP
Old 11-01-2010, 12:34 PM   #9 (permalink)
i highly doubt that its wheel alignment, as when i load up one sideof the suspension at speed, it goes away, and its intermittent.
as far as checking for play, can i do that with the axle in still or should i remove it?
Old 11-01-2010, 12:35 PM   #10 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
yeah and if your steering goes super lose then that means 1 or both shafts are kaboonk.
1994 Corolla
GTChink is offline   Reply With Quote
Old 11-01-2010, 01:41 PM   #11 (permalink)
i just dont know how tight 220k mile steering should feel :p
Old 11-01-2010, 04:57 PM   #12 (permalink)
wheel alignment and wheel balance are totally different things
Old 11-01-2010, 07:19 PM   #13 (permalink)
i know exactly what youre talking about, im not stupid man.
ive built a car before, i just havent had halfshafts go bad.
got the wheels and tires new less than 8 months ago.
wheel alignment was done about 2 months ago.
Old 11-01-2010, 08:28 PM   #14 (permalink)
In that case I'll leave my experience as a suspension technician out of your thread.
Didn't realise you had built a car before.
Old 11-02-2010, 02:20 AM   #15 (permalink)
no, i welcome your advice, i was just thinking it was understood that i got alignment after tires.
my toy, waiting on some 280zx adjustable tension rods for some caster adjustment.
