Where is the fuel filter located in my 97 Corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2010, 01:41 PM   #1 (permalink)
View DaveServo's Photo Gallery
My 1997 Corolla has only been starting about half the time. Sometimes it seems it's out of gas and sometimes it starts up. I want to replace the fuel filter to see if that's the problem. Where can I find it and is it difficult to replace?
DaveServo is offline   Reply With Quote
Old 11-01-2010, 01:55 PM   #2 (permalink)
Gameroom cash: $151000
View demonics12's Photo Gallery
its in the back corner on the drivers side, its in front of the brake booster, hard to miss...
it sounds like fuel pump to me, but you should replace the filter just in case.
good luck!
demonics12 is offline   Reply With Quote
Old 11-02-2010, 05:17 AM   #3 (permalink)
View 94PrizmDD's Photo Gallery
It doesn't hurt to replace the fuel filter they're cheap less then 20$. You can def change it yourself. Not that hard if you have the proper tools. The Haynes manual has a good write up. If you don't have one i can do a write up for you.
94PrizmDD is offline   Reply With Quote
Old 11-02-2010, 08:55 AM   #4 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
More likely a relay problem.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 11-02-2010, 09:52 PM   #5 (permalink)
Bad Black 96
badcompany87's Avatar
View badcompany87's Photo Gallery
Hey I have a question. My fuel pump gave out about a week ago, so I ordered a new one on eBay. It said it came with a new pump and filter. Well I got the pump...and then I got this orange bag with a plastic piece inside...it almost looks like the bag they use for IV at a hospital, only much smaller...is this thing the fuel filter sock? I've been researching fuel filter parts and thats the only thing that Ive found. Can you tell me what I do with this thing?
badcompany87 is offline   Reply With Quote
Old 11-02-2010, 10:01 PM   #6 (permalink)
BoyYota's Avatar
It should be a mesh-like pouch. It should have a circular piece that you clip to the top of the fuel pump.
The Following User Says Thank You to BoyYota For This Useful Post:
badcompany87 (11-05-2010)
Old 11-05-2010, 06:44 PM   #7 (permalink)
Bad Black 96
I got it installed, thanks man.
Old 11-05-2010, 11:35 PM   #8 (permalink)
Bad Black 96
Hey man, I've been having the same problem with my car starting half the time. You helped me when I posted a few weeks back about my car not starting. Well I got the new fuel pump and it installed it. It starts more often now, but it's still giving me hell. I am going to replace the fuel filter also, but what should I check to see if it's a relay problem?
Old 11-06-2010, 12:18 AM   #9 (permalink)
BoyYota's Avatar
Bust out the old multimeter and see if the power connector at the pump is receiving enough voltage.
Though I think there is a method to test the relay itself, I'm not sure of it. I think I've seen it somewhere online or in a manual though it might not have been for our cars. The fuel pump relay is located behind the radio by the way. In my previous car when I had this problem I just went and bought it without even testing it because it was just $12 and under the hood and it fixed it.
badcompany87 (11-06-2010)
Old 11-06-2010, 12:24 AM   #10 (permalink)
Bad Black 96
Thanks so much, you've been really helpful. Ill do this first thing in the morning.
Old 11-06-2010, 04:06 PM   #11 (permalink)
Bad Black 96
So I've been looking for the relays and autozone quoted me $134?! Is this right? And when I checked autozone and kragen both of them say "not available online or in stores, call for details"? Its the EFI Main Relay under the hood right? And then the fuel pump one is behind the radio, I unplugged that one to de-pressurize my system when I changed the fuel pump...why are they so expensive?
Can I use a multi-purpose relay? Kragen has it for $16.99...
Old 11-06-2010, 05:13 PM   #12 (permalink)
BoyYota's Avatar
Yeah there's a lot of stuff they like to rip you off for. The part # RY920 apparently works as a multifunction relay and they sell it for around $20. RockAuto has it.
