Not Starting after Oil Change
Hi All TN members.
I did an oil change on my 1994 corolla 1.8 tonight . I filled up my engine with 3.5 L (3.69 Qts) of 10w30 oil and i noticed it was a bit over the full line on the dipstick. as i put the amount of oil recommended from service manuals i did not seem too concern about the overfill as it would only be minor overfill.
Did the leak test by starting my car. I noticed when i started the car it had a sort of burp then the usually crank and start.
Turned the car off after a couple of minutes as i checked the oil filter and drain plug is tight and not leaking any oil.
About an hour later i started the car again it had that initial burp then crank and start. made a short trip and went home no problems starting the car again on the way back home just that burp then crank + start again.
Now finding it a bit odd that it is doing that i went back out a couple hours later and tried to start the car again this time it would not start. no clicking or cranking .
Turned the key off , then back to start nothing would happen until 3-4 tries then it would just start. I had to wait till the warning beeps ended then cranked the starter and it would start
any ideas what is causing this to happen. can it be the oil pressure ?
is it my starter ? usually when the starter goes there is a loud clicking sound . I did not hear this .
Battery seem fine . but going to test the battery
Please reply , need help with this one
