AE101 4AGZE Air fuel ratio gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2010, 06:19 PM   #1 (permalink)
View Steven T's Photo Gallery
I have spliced the signal wire from my afr gauge into the black and white wire from the ECU
Is this right?
It's just that when I turn the ignition to ACC the gauge lights up fully rich, then when I start the car the ratio goes from stoich to lean and then off the dial, it takes maybe twenty seconds for it to go completely off the dial. Whenever there's more than maybe 50% throttle it goes all the way to the right., fully rich
Is it the car, wiring or gauge?
Cheers
Steven T is offline   Reply With Quote
Old 11-13-2010, 07:13 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Welcome to the forums! I've never installed an air/fuel ratio gauge before, but I had a search for some 4A-GZE ECU pinouts online and the black and white wire that you spliced into definitely seems correct. Perhaps you need to upgrade to a wideband o2 sensor for it to work. Might be worth getting some free advice over the phone from an auto electrician tomorrow. Good luck!
Old 11-13-2010, 11:39 PM   #3 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
Using the factory lambda/O2 sensor for an AFR gauge will give you bling and nothing else - they use a narrowband sensor and thus only have three levels - lean, stoich, and rich, so all you'll get is a needle flicking wildly from left to right showing nothing useful.
As Kiwi said, if you really want a proper AFR readout then you'll need a wideband sensor.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 11-15-2010, 08:15 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
The only time you can get a real reading is at WOT.
-SP
Old 11-15-2010, 02:54 PM   #5 (permalink)
So there's no need to get alarmed?
And it should work on a wideband sensor?
Also what is WOT?
Old 11-15-2010, 03:56 PM   #6 (permalink)
Full Throttle
Also what is WOT?
Yeah it should work if you get a wideband sensor. WOT = wide open throttle.
