FINALLY found reason for oil usage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2010, 03:33 PM   #1 (permalink)
View spingley's Photo Gallery
Well after months of trying to figure out why my 2000 Prizm was going thru oil like there was no tomorrow, it turns out the oil filler cap was bad. I had pulled the plugs after doing a search on this site for oil usage but they looked almost like new, I could not see any oil dripping from the engine anywhere but around the oil filler and I assumed that was from when my wife was adding oil she was just dumping it, but found out she had been using a funnel. Then a friend mentioned that he had a car that had a bad cap so I looked at the filler cap and the rubber gasket was dried up and shrunk back into the cap and was doing nothing. Next I started the engine and removed the cap and the back pressure was actually slowly pushing a film of the oil up the sides of the hole and spraying it out, not a lot mind you but add up hours of driving and it can be significant. Two of the many quarts of oil I have put in there would have paid for the new cap from Autozone, if I had only known!! Now it hardly uses any oil at all. UPDATE-Actually I had meant to post this in the 8th generation forums but maybe this will apply to 7th generation engines also.
spingley is offline   Reply With Quote
