Just completed a full weekend of work on the Corolla 7A-FE. As I posted in another thread, this is the work I did and parts replaced:
- Replace radiator & heater hoses (brand new radiator)
- Replace timing belt
- Replace water pump & water neck hose ($14 for a 1 ft. length of Gates 1 3/8" hose that I cut down to 3" long!)
- Replace front main oil seal
- Clean off and replace liquid sealant on both oil pan and block reinforcement section
- Replace fuel filter
- Replace spark plugs
- Replace valve cover gasket, plug tube gaskets, and bolt grommets
- Replace coolant bypass hose
- Repair broken TVV vac hose port
Now after I got everything back together, I'm hearing an odd sound from the timing belt end of the engine. At first I thought the A/C belt was rubbing on the timing belt cover, so I removed the belts, removed the A/C tensioner pulley and made sure all the washers and spacers were correct, and put it back together again. Still making the sound. It doesn't really look like anything is rubbing, but I cannot figure out what's making this sound.
You can hear it very plainly in this video, but you can't see much due to crappy iPhone video.
