Originally Posted by jvw315
Sir Kiwi i connect the E1 and the Te1 on the diagnostic link but when i switch on
(not started)the check engine flashes what does this mean ...and can you pls give me the check engine trouble codes on my car thank you so much for the help
Ok, that's good. That's what it's supposed to do. The flashing indicates the code it is giving you. For example, the code for a faulty oxygen sensor is 21, which would be shown as two 0.5 second flashes, a 1.5 second pause, and one 0.5 second flash. Take note of how many flashes and pauses you get. If no codes are detected at all, then the check engine light will flash continuously with only 0.5 seconds pauses in between.
The meaning of the codes are as follows:
12 = RPM signal (no RPM signal to ECU within several seconds after engine is cranked)
13 = RPM signal (no RPM signal to ECU with engine speed above 1,500rpm)
14 = Ignition signal (no ignition signal to ECU)
16 = ECU control signal
21 = Main oxygen sensor
22 = Coolant temperature sensor
24 = Intake air temperature sensor
25 = Oxygen sensor or circuit (lean)
26 = Oxygen sensor or circuit (rich)
27 = Sub-oxygen sensor
31 = MAP sensor
41 = Throttle position sensor
42 = Vehicle speed sensor
43 = Starter signal
51 = Switch condition signal
52 = Knock sensor signal
53 = EGR system
