EGR valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2010, 05:31 PM   #1 (permalink)
jvw315's Avatar
View jvw315's Photo Gallery
EGR valve
im trying to find the EGR valve on my Toyota corolla 1993 AE-101 4afe engine automatic transmission but i cant locate it ...maybe my car model does not have a EGR valve i need your help sirs and kindly post some pics where i can locate it if there is thanks
jvw315 is offline   Reply With Quote
Old 11-26-2010, 05:37 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $614831
View Zembonez's Photo Gallery
Yes you should have an EGR valve and it should look something like this:
Zembonez is offline   Reply With Quote
Old 11-26-2010, 08:45 PM   #3 (permalink)
jvw315's Avatar
sir thank you for the reply but i need the picture of the engine and where it is located ..i know whats a EGR valve look like but i seriously cant find it or just give me the information where to look at & what are the components near it ...thanks
Old 11-26-2010, 10:19 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Since you're from the Philippines and your Corolla is a GLi model, you won't have an EGR system as it's a Japanese model. The Japanese models had different emissions standards than the US models. On the US models, the EGR valve is located near the throttle body.
Here's a diagram that I just scanned from my Haynes manual:
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
jvw315 (11-27-2010)
Old 11-26-2010, 10:21 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
AHA! My apologies for not catching the fact that you are not from the States. If you do not have a US car, there may not be an EGR valve. Sorry about that.
Old 11-26-2010, 11:12 PM   #6 (permalink)
View daviidsjdmx's Photo Gallery
Also on the EGR VACUMM MODULATOR, theres a cap which has a filter under it. Make sure you clean it.
My wagon just threw out a code 71 but i dont have time to fix it, im just going to the junkyard to grab an EGR valve, sensor, and modulator.
daviidsjdmx is offline   Reply With Quote
Old 11-27-2010, 04:24 AM   #7 (permalink)
jvw315's Avatar
thanks kiwi corolla another thing i tried what you said in my another thread about check engine light that i should put a paper clip on diagnoses box one end on Te1 and the other on E1 but when i make the switch just on (not started) the engine lights on like a normal switch on ..no flashing the code how is that thanks
Old 11-27-2010, 04:29 AM   #8 (permalink)
Full Throttle
No worries . As for the Check Engine Light, is it remaining solid when you turn the ignition to the 'ON' position? Or is it illuminating for a second and then turning off, like normal? The light should start flashing if your connection between the TE1 and E1 ports is secure. Even if no fault is detected it should still flash continuously with no pauses in between. Be sure to check that your connections are secure, as sometimes the grease inside the ports can cause poor contact. Don't remove any of the grease, but wiggle the paper clip around a bit. It might pay to have someone else help you while you sit inside the car and wait to see if the CEL starts flashing.
Old 11-27-2010, 07:10 AM   #9 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
hmm filter in the EGR VM there's a filter? Does the Haynes have cleaning procedures for that? Our 96 OBDII recently threw a code for the EGR, and I had the guy at the parts store clear it with his scanner, and it hasn't come back since. Wonder if I just need to clean that filter.
PatrickGSR94 is offline   Reply With Quote
