oil pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2010, 03:02 PM   #1 (permalink)
View agmgranturismo2006's Photo Gallery
oil pump
i noticed recently that the oil pressure indicator in the dash takes a longer time to go off after starting the engine could that be an oil pump failure and if not what could the problem be?
[SIGPIC]GRAN TURISMO the real driving
simulator
agmgranturismo2006 is offline   Reply With Quote
Old 11-28-2010, 03:40 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
it could be a weak oil pump, a dirty/failing sender (gunk in the hole where it reads pressure), or a worn engine (loose bearings need more pressure).
Old 11-29-2010, 08:11 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
replace the sensor FIRST. They do wear out and go bad. After that get a real gauge and confirm your pressure is OK or bad. MINIMUM psi is 5 per 1000 rpms. Also if you are using a cheap oil filter (typically brand "F") you can have pressure problems.
-SP
Old 12-02-2010, 10:18 AM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Sounds to me like a your engines just getting a little old.
So long as you keep an eye on the oil level and the oil pressure light turns out within a few secs, you've got nothing to worry about.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
