Rear doors locks not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 10:37 AM   #1 (permalink)
View rocos's Photo Gallery
Both the rear doors locks do not respond when I lock/unlock the vehicle. I have to manually open the doors. Any idea of what could be wrong?
rocos is offline   Reply With Quote
Old 12-01-2010, 03:08 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Welcome to the forums! The first thing I'd do is remove the rear door cards and check to make sure that the door lock linkages are not seized or damaged. It would be a strange coincidence for them both to fail at the same time due to the linkages, but it's worth checking. If everything looks fine and moves freely in that regard, then disconnect the wiring connector from the door actuator, grab a digital multimeter and check the wiring for continuity between the door lock actuator connector and the body control module (BCM - located behind the glove compartment). Also check that there is continuity between the door actuator switch wire and the earth wire in the door lock actuator only when the door is unlocked. Good luck!
