No reverse lights!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2010, 06:53 PM   #1 (permalink)
View herb617's Photo Gallery
No reverse lights!!
I check the fuses and the bulbs;my '97 Corolla (automatic transmission) reverse lights won't light up. I'm thinking the neutral switch might be the problem, but does anybody have any other ideas? I'm really frustrated about this, because I failed the inspection. Thanks guys.
herb617 is offline   Reply With Quote
Old 12-02-2010, 07:16 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Welcome to the forums! The reverse switch for models with the automatic transmission is part of the inhibitor switch on the side of the gearbox. It may not be aligned properly to sit in the 'Neutral' position, or it could be faulty. The first thing I'd do is raise the vehicle, remove the splash guard covering the transmission, disconnect the wiring connector from the inhibitor switch and measure the continuity between terminals 2 and 3 of the inhibitor switch by using a digital multimeter.
Move the selector lever to Reverse and check that continuity exists between terminals 1 and 4 of the inhibitor switch. Check that continuity fails when the selector lever is not in Reverse. If a fault is indicated, replace the inhibitor switch.
If necessary, select Neutral, loosen the retaining bolts and adjust the inhibitor switch until the arrow on the selector lever is aligned with the line on the inhibitor switch.
Good luck!
Old 12-02-2010, 07:54 PM   #3 (permalink)
Thank you so much. I've located the switch and I will work on it this weekend. BTW, where can I get a digital multimeter? Thanks again.
Old 12-02-2010, 08:05 PM   #4 (permalink)
Full Throttle
You're very welcome (feel free to click the 'Thanks' button below my post if you like ). You can buy a digital multimeter at any good electrical store, or even from big chain retailers. It's a good device to have, and is bound to come in handy again in future.
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
herb617 (12-02-2010)
