Prizm Heater Not Working - Blend Door?
I am running out of things to look at here, so I thought I would hopefully get more ideas on why my heater is not working very well.
My heater is slightly warm when the car is idling, but blows cool/cold air while driving and the faster I go the colder it gets. It's never hot, even on full blast. I replaced the heater core over the summer since it was leaking. Thermostat was replaced, car is running at normal temp (halfway mark), checked the heater valve, coolant is full, I doubt it has air in it anywhere. I can't think of what else to check EXCEPT the blend door, and I don't know how to check that. From what I could read up on it, it could be a problem.
Here is where I'm not sure if I messed anything up. When I was replacing the heater core, I completely removed the Evap core since it had the biggest mouse nest I've ever seen in it. The A/C didn't work as it was (it's got a leak somewhere) I decided not to spend the money for the new evap core. I don't use the A/C anyways, so I figured I wouldn't worry about putting the mouse-nest one back in. Now I'm not sure if this could have caused a problem with the blend door, or if maybe I messed up the blend door some how when replacing the heater core.
Frankly, I don't understand the HVAC system. I could just use a little insight. I understand how the heating system works (for the most part) I just don't understand how it relates to the A/C system.
Bottom line - Is it possible that removing the evap core caused this problem? If so, is there any way to fix this without actually fixing the A/C system or buying a new evap core? Does it seem like it could be the blend door? Is there any way to easily check the blend door? Or will I need to take the whole car apart again?
I tell you, that heater core sure was a PITA to get to and I don't want to do that again unless I have to!
Thanks in advance for the help!
