Did the fun in the snow cost me a tie rod?
Every winter, after the first heavy snowfall, I take out my [1997] Corolla to an empty parking lot. I spend about half hour relearning how to drive in the snow to be prepared for nasty surprises on the road: hard turns and e-brake induced skids included.
I did this tonight, but I didn't get to my finishing move (*grins* the donuts) because I developed a serious pull to the right (10-15 degrees of the steering wheel to the left allows the car go straight) that I have to counter with a firm hand because if I stop steering slightly left it will immediately start moving to the right. I also developed the knocking sound as I turn the steering wheel side to side when I'm parked.
So what do you guys think? I'm guessing a worn tie rod end finally gave. Bent tie rod at the worst (a bit unlikely because I didn't hit anything).
How hard will it be to replace the tie rod? How about the tie rid end?
How do I know if it is inner or outer?
Is there some sort of DIY guide for this procedure?
I'm guessing that this will cost me an arm and a leg if I was to take it to the shop, but how much?
I know I should replace both sides of what ever is broken on one side - am I correct?
Will alignment be able to fix this? My guess is no.
Thanks a lot for your time!
