changing front running lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2010, 10:35 AM   #1 (permalink)
View aaron30's Photo Gallery
Anyone know an easy or correct way to change the bulb in a 96 front running lamp, i tried taking out the lamp assembly out but could not get it to come out.
aaron30 is offline   Reply With Quote
Old 12-09-2010, 10:47 AM   #2 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
you're just replacing the bulb? if so, just twist the plug at the back of the headlight housing counterclockwise and pull out! Push spring retainer and remove bulb. Reverse for install. No need to remove the entire headlight housing unless you're replacing the entire headlight housing.
1994 Corolla
GTChink is offline   Reply With Quote
Old 12-09-2010, 01:42 PM   #3 (permalink)
I'm talkin about the light inside the turn signal
Old 12-09-2010, 01:59 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Remove the screw from the corner light which goes into the headlight housing and then pull the corner light away from the front of the car. It might be hard to get out at first, but just keep pulling at it and it'll eventually pop out. Once out, simply turn the socket anticlockwise and you'll be able to replace the bulb.
Old 12-10-2010, 01:47 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
It may be corroded in the socket enough that it wont push in and turn. Try using some penetrating lubricant and see if you can loosen it up. You may have to crush the bulb and deform the lamp base to get it loose.
-SP
