Follow-up
OK, I found that it gets inserted into the bottom (engine-side) of the air-filter housing/box. There is an obvious rubber grommet where it belongs. However, I'm still curious what it is. Since it is solid plastic (no openings on the actual sensor end), I'm guessing it must be used for sensing temperature. However, why would the ECU care about the temperature of the air-filter housing?? We are considering an after-market air filter (such as the Weapon-R Secret Weapon) and their instructions don't mention this sensor at all, nor does it have a hole to support it. If an aftermarket filter & pipe doesn't have a hole to re-locate this puppy, does it just get unplugged, lay loose, or what?
