make sure the system is totally flushed of debris and old fluid and purge the air correctly.
turn the rack to the left and right lock with the engine off while someone adds fluid to the reservoir, back and forth until no air is purged. with the rack at the left lock, turn the car on briefly and back off and add fluid as needed, then goto the right lock and do the same. wait about 10 minutes and repeat the whole process. then start the car and work the wheel side to side lock to lock, there should be almost no whining or frothing of the fluid. if there is, shut it down and wait for the air to settle up and then repeat the whole bleeding process again.
