Rear Brake and Headlight Question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2010, 05:19 PM   #1 (permalink)
Bad Black 96
badcompany87's Avatar
View badcompany87's Photo Gallery
Hey Nation,
I'm having a few small issues with my car I'd like to correct. Lets start with the headlights. My headlights barely project. They shine bright, but I can't see too far or too wide. Any suggestions on better bulbs? And my rear passenger brake, it squeals pretty loud when I reverse off the drive way, it happens more when it's cold. I had the shoes replaced about year ago, only the passenger side squeals and mostly when Im in reverse, any idea what could be causing this? One more thing, this started yesterday, twice I've tried making a regular right turn and my steering wheel is super tight, it feels like it's locking up, I really have to pull it to turn. It's only happend twice, I've made numerous left turns and right turns no problem. What could be causing it? Any help is much appreciated, thanks guys.
Last edited by badcompany87; 12-19-2010 at 05:36 PM. Reason: I experienced another issue :(
badcompany87 is offline   Reply With Quote
Old 12-19-2010, 06:13 PM   #2 (permalink)
AE-202 Owner
miib14's Avatar
Gameroom cash: $356141
View miib14's Photo Gallery
the squeling could be because of handbrake cables staying on...
jack the car up, let go off handbrake and try spinning that back wheel...
★ 1993 Toyota Corolla Saloon ★
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
185 Bhp & 142 lbft Torque
miib14 is offline   Reply With Quote
The Following User Says Thank You to miib14 For This Useful Post:
badcompany87 (12-20-2010)
Old 12-20-2010, 01:03 PM   #3 (permalink)
View Redline322's Photo Gallery
Either your parking brake is sticking, the side is out of adjustment or if the pads are old, the pad material could have broken loose and jam on the other pad material when in reverse. Pull it apart and and inspect it, replace parts if needed. As far as the steering goes, if the engine was cold when it happened, you might just be a little low on power steering fluid and once the fluid warms up, it expands and brings the system back up to pressure.
Redline322 is offline   Reply With Quote
The Following User Says Thank You to Redline322 For This Useful Post:
Old 12-20-2010, 05:49 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Excessive dust trapped insice the brake drums is the most likely culprit for the noisy rear brakes.
-SP
The Following User Says Thank You to speedy25 For This Useful Post:
