How to remove panal around the stereo to take it out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 02:48 PM   #1 (permalink)
Gameroom cash: $123850
View c_huynh32's Photo Gallery
Hi,
I tried searching and i couldn't find it, so if it's posted please point me to the direction.
I would like to put back my original stereo as I am selling the car, the new stereo was installed at a shop.
I pulled out the 4 knobs (fan, temp. etc.), took out the 2 screws at the bottom. After that I try to pull out the black panel around the stereo and it doesn't budge, is there clips there i take the screw driver or something to pry it out?
thanks,
Chris
c_huynh32 is offline   Reply With Quote
Old 12-20-2010, 03:27 PM   #2 (permalink)
View hungt1999's Photo Gallery
if I rembember correctly, the 2 screws near the climate control sliders are the only ones to be removed. I find it easier to remove the ash tray and start pulling the trim piece from the bottom near the ash tray and work your way up.
hungt1999 is offline   Reply With Quote
Old 12-20-2010, 03:48 PM   #3 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
Just pry it from the side after you've removed the 2 screws.
1994 Corolla
GTChink is offline   Reply With Quote
Old 12-20-2010, 09:27 PM   #4 (permalink)
View 96coroll's Photo Gallery
i didn't have to remove any screws. Just take off the knobs. And pull hard. i have 96 corolla
96coroll is offline   Reply With Quote
Old 12-20-2010, 09:38 PM   #5 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
As others have said, it will just pop out towards you once the two screws are removed. Once it has popped out of the opening, be sure not to pull too hard as you need to unplug the electrical connectors for the clock (if equipped), hazard light switch and rear windscreen demister switch. Simply push the tab down on the each connector and they'll slide out, allowing you to remove the stereo surround.
Old 12-21-2010, 09:35 AM   #6 (permalink)
Thanks everyone, I just spent an hour trying very carefully to prying/pulling the panel out was hard haha, the clips held it on pretty good.
I have a clock so thanks for the warning Kiwi
Old 12-25-2010, 03:30 AM   #7 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
The two screws aren't required for the radio/air-con panel - they hold the pocket/ash-tray/cigarette lighter panel in. For the radio panel you just need to pull the 4 air-con knobs off as stated above, then just grip it firmly on the rib between the two sets of controls and just pull it straight towards you. You won't be able to pull it out far though before you have to disconnect the plugs for the hazards and the rear demister (and the clock if you have one next to the air vents), so be careful not to rip anything out.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 08-08-2011, 12:38 AM   #8 (permalink)
Dirty Dude's Avatar
Gameroom cash: $121500
View Dirty Dude's Photo Gallery
Perhaps not required, but it's a PITA with those two screws in, at least for me it was. The radio panel has a lip at the bottom that engages behind the ashtray panel and wouldn't budge because of it. It's not a problem if you can get the radio panel clips released starting from the top, but good luck with that.
I debated whether or not to resurrect this old thread and decided to because I found it by searching and wanted to point out for others who might do the same that it is a good idea to remove those two screws. It's not exactly a big job anyway...maybe 10 seconds with a screwdriver.
1994 Pickup base model and a couple Mustangs.
Dirty Dude is offline   Reply With Quote
