Starter Issue Just Spins - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 10:44 PM   #1 (permalink)
Only Drive if I have to
Yodadex's Avatar
View Yodadex's Photo Gallery
I have this problem with my starter. It takes several tries to engage the starter to crank the motor. It sounds like the over-running clutch in the starter is going out. It's rather annoying after a while.
I wanted to get second opinions if anyone has had similar issues. If so how much are parts for the starter?
I probably need to find the over-running clutch part.
Let me know if anyone has any good links on parts.
Thanks
Stephen
Stephen
may i help you?
Yodadex is offline   Reply With Quote
Old 12-21-2010, 06:22 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
It could also be bad teeth on the flywheel, or something really dumb like the starter bolts have come loose.
Unless you have a good supplier of internal parts in your area, its easier AND usually cheaper just to get a reman starter.
-SP
Old 12-21-2010, 06:27 PM   #3 (permalink)
Yodadex's Avatar
cool thanks. Yeah the manufactured part is $100. I think Ill just buy it. According to the starter manual it says it's a failing over-running clutch inside the starter.
http://www.autoshop101.com/forms/h7.pdf
Stephen
may i help you?
