Originally Posted by superdave1984
Runs good? No leaks or issues? What would you want for it shipped to 38260? When could you ship it? Also, if mine is a 1.8, will my accessories all bolt right up? How about the flywheel? Bellhousing? You get the idea. I will check tomorrow to see what it is.
I can ship it tomorrow really depends on you. I will have pictures up tomorrow of the motor
But it ran strong with no problems it actually has spark plug wires that are probably 3 months old and there is no leaks and all of the wiring harness is there. Like I said before I only took it out because I swapped in the silvertop. And with the knowledge ive been given, the A series motors share the same bolt pattern so your transmission will work. Im not sure if the ratio's would be the same
Also mine was an auto BUT i have a 4afe manual ECU which would be included with the motor. PM and we can continue discussing if you have further interest.
