Sounds like the switch itself may be worn. Disconnect the negative terminal from the battery and give it five minutes, the trim piece by the switch is right next to your air bag control unit. You can take the rear piece of the center console trim off by removing the two screws under the arm rest/in the storage area, and remove the screws on the left and ride side where it slides onto the console piece around the shifter (Crappy description I know). You'll see the switch around where the black "shroud" is on the bottom of the parking brake handle. Sorry again for the lame description, it's been quite a long time since I've hand to deal with it. You can try cleaning around the switch, but IIRC it's the sealed plastic type so you'll likely need to replace it. Hopefully someone can post a better description.
