Need to step on gas to start in cold weather
Hello,
I have a 96 Geo Prizm with 171k on it. This problem just started this winter. I have recently changed the oil (5w 30), spark plugs, plug wires, and fuel filter after noticing I need to give the car gas in colder weather (below 25 degrees) after sitting over night in order for the car to start. The car cranks over and wants to start but I need to press gas pedal to start. I have a remote starter and it will not start with it in the cold weather because the gas pedal is not applied. Once started it will sputter a bit and then run just fine.
I have tried fuel injector cleaner before the weather got cold and looks like it is not helping.
Any thoughts on the cause? Injectors? Fuel Pump?
Thanks for your help.
