Drivers Side Door Leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 11:55 AM   #1 (permalink)
View dj26's Photo Gallery
gen 7 Drivers Side Door Leaking
Hi all,
I felt that my door from inside was getting moisture and random water spots were everywhere! I decided to take of the panel. It is leaking pretty bad. What can be causing this? Should the window seal be replaced? Suggestion/comments...? Thank you.
Uploaded with ImageShack.us
dj26 is offline   Reply With Quote
Old 12-29-2010, 04:16 PM   #2 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
yes sir you are correct if the rubber seal is hard to the point of easy brakeage then it needs to be replace with a new one. another way to find out if its the rubber seal close the window, open the door, with the door panel off so that you can see whats goin on and run water from a hose on to the glass and let it run down to the seal to see if water is coming throught the seal to make sure.
topnotch is offline   Reply With Quote
Old 12-29-2010, 06:41 PM   #3 (permalink)
Any suggestions on where to buy seal from? Google and eBay are not coming up with any results!
Would something like this work?
http://www.autopartswarehouse.com/sk...ts+%26+Mirrors
OR
http://www.carpartswholesale.com/v5/...Listing+Page:2
Old 12-30-2010, 05:35 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
dealer item
-SP
