smokey 101e - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 09:07 PM   #1 (permalink)
View m.mcarthur's Photo Gallery
smokey 101e
typically this from my 96 101e corolla sedan
come down a hill & well smoke, smell it see it. has done it since i bought it 5 years ago @108,000 now 142000.
Is this common with these as i have seen others blow smoke at the bottom of a hill too ,but the oil doesnt drop much on stick.
Rings or valve seals?
any advise appreciated thanks
m.mcarthur is offline   Reply With Quote
Old 12-29-2010, 09:19 PM   #2 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Huge valve seal problem with these engines apparently. Something like that is exactly what I was told to do to test for valve seal problem, go down hill, let go of the gas, and then hit the gas again and if there's smoke it's the valve seals. Apparently an easy way to tell if it's rings is if it's smokes all the time. Not many people know these things though, gotta do a lot of research like I have.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 12-30-2010, 02:57 AM   #3 (permalink)
thanks a lot for that, may pull head off & do but may be opening a can of worms, who knows ay.
Old 12-30-2010, 03:07 AM   #4 (permalink)
BoyYota's Avatar
I guess you never know, but it would be worth it to try. It's worth it for me because I burn a quart every 200 miles or so. I can't keep on like this.
You may not need to pull the head to do it. I think you can do it by just removing the valve cover and cams, but not sure. I actually meant to ask that question here soon.
Old 12-30-2010, 04:03 AM   #5 (permalink)
Gameroom cash: $201310
View ganda1f's Photo Gallery
Yes, you can do it w/o removing the head. I asked the same question some time ago. Have a look on this thread:
Valve stem seals' impact on oil consumption
As for the tool to depress the valve springs, here is a home-made one that does not cost a fortune
4afe tear down pictures
ganda1f is offline   Reply With Quote
The Following User Says Thank You to ganda1f For This Useful Post:
BoyYota (12-30-2010)
Old 12-30-2010, 04:52 PM   #6 (permalink)
thanks guys for this info, the engine shoulldnt be stuffed @143,000 as it goes real well wonder what mileage it should run through to?
thanks again.
Old 12-30-2010, 05:28 PM   #7 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Check the PCV system carefully before disassembly.
-SP
Old 12-30-2010, 10:54 PM   #8 (permalink)
i have checked the pcv in rocker cover seems free what else shhould i check in this regard thanks.murray.
