Oil leaking into my cooling system... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2011, 02:07 AM   #1 (permalink)
View 94PrizmDD's Photo Gallery
Hi I seem to have a major problem on my hands. I have oil leaking into my cooling system. This happened to me a few years back and I replaced the radiator and it seemed to have fixed the problem. Unfortunately by trying to slow down my oil leak, I added some engine restore. It was probably too much for it because I have oil going into my cooling system like crazy. Its not going back into the engine. People have told me its the head gasket. Has anyone had this problem before? How bad is oil in the cooling system?
94PrizmDD is offline   Reply With Quote
Old 01-05-2011, 03:22 AM   #2 (permalink)
View ae92gtz's Photo Gallery
sounds like the oil is leaking through the headgasket from the oil galleries and into the water galleries, you should really get the gasket replaced
ae92gtz is offline   Reply With Quote
Old 01-05-2011, 04:27 AM   #3 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
Do a Leakdown test; will tell you if you have a bad headgasket or not. But Like others said, it might be your headgasket. A diagnosis is a must before you tear anything down.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 01-05-2011, 11:42 AM   #4 (permalink)
View mvftw's Photo Gallery
Take off your oil fill cap and look at the bottom (where the threads are). If it looks like chocolate milk then you have a blown HG...
mvftw is offline   Reply With Quote
Old 01-05-2011, 09:10 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
use Nusdogg's advice to confirm the problem, but from your description its almost a given. Very rarely do the "snake oils" actually fix a problem.
DONT FORGET when you have installed the new head gasket, to flush the cooling system. Your cooling efficiency is severely compromised when there is a coating of oil on all the cooling surfaces.
-SP
Old 01-06-2011, 09:12 AM   #6 (permalink)
Gameroom cash: $816901
View zythr's Photo Gallery
Good luck. I hope you find a solution
zythr is offline   Reply With Quote
