Originally Posted by SupaRitz
The part that's inbetween the two tailights, idk what to call it but is there anyway to remove it? I think it looks really bad and im going to get a new paint job so i can just paint over the blank space.
--96 corolla
It's called a garnish
. To remove it, undo the four 10mm nuts on the underside of the trunk lid (you'll need a ratchet), and then give it a firm pull on each side to disengage the plastic clips. I'm not sure if you're just planning to remove it temporarily while you paint the car, or if you want to remove it for good, but if you want to remove it for good then bear in mind that there will be visible holes once it's removed, and you'll be able to see your trunk lock poking out. I'd recommend either leaving it as it is, spraying it the same colour as your car, or getting a reflective garnish to match your tail lights from a higher spec LE model
