I will b replacing both calipers, pads and rotors for the shimmy issue. The one rotor that the pad is worn down all the way, is warped.
For the trans issue, while ding an oil change I noticed that trans fluid is leaking at the seal where the trans meets the block. Looks like there is a gasket there. I can't find out where to get this gasket. Any ideas, or part numbers??
Threw some Lucas Trans additive in there to prolong the devastation until I can replace the gasket. Also added more trans fluid as it was way down. Explains my morning problems.
So is it alot of work to drop the transmission? I have a hobby shop with lifts and all the tools I would need.
