In Aus, brake lights, headlights and hazards (not indicators though) must be able to operate with the ignition key in any position (or even removed), however there is logic in the BCM so that the headlights turn off when the driver's door is opened and the ignition turned to ACC or OFF - this is to stop you leaving the lights on after you get home (there's no buzzer though), if you need to force the headlights to stay on after the car is stopped then you just turn the headlight switch off and then back on (the door switch basically acts as an edge-trigger, after it has tripped it no longer affects the system).
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
