Originally Posted by Molerj
. Car will stop but I can't get brakes to lock up and braking power is definitely not what it should be. It seems like not enough brake fluid pressure is being applied to the calipers & rear shoes.
It does take a while for the shoes and pads to mate with their drums/rotors.
There is also a LOT of difference between discount brake pads and some good ones. If you really want your brakes to stop you NOW a set of shoes in the $100 range isnt out of the question. The parts from the discount stores are only adequate. Old rubber hoses are also part of the problem you describe since when they start to degrade they will expand when braking is applied.
As my thread that gandalf quoted says I had a MAJOR difference in pedal travel after fitting the shoes to the drum.
-SP
